For an AMD CPU on stock settings that looks about right. What are you using to stress test? Prime 95? Also would be helpful if you show a CPUZ screenshot.
Must be a noisy system. The CPU fan is 3500ish? For the price you spent on the system, spend another $40 and get a better CPU cooler such as the Cooler Master Hyper 212+ or EVO.
I've heard and seen good things about this new cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103105
I don't have any hands-on time with it, but it may be another cooler to consider.
Another thing, the box labels don't seem to say AM3+ on it.. I have a Gigabyte 990x mother board with 8120 processor, so its a AM3+
Will all the older models including this one fit?
^^^ Yes. If you click on the details tab you'll see that it support AM3+. Which makes sense as all AMD CPU from AM2 to AM3+ uses the same physical 938pin socket.
Haven't used that HSF so can't speak for it's quality. But IMO, I'd stick with the Hyper 212+ or EVO which is known to be great value or go high end if I want to upgrade. Middle of the road HSF is so so with me.
Example of high end: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
