neokosmitis
- Mar 20, 2016
guyz if u could help me too
my specs are
Motherboard: Asus Sabertooth 990Fx R2.0 - CPU:AMD Fx 8320 GPU: Sapphire VGA R9 380v2 Nitro Dual OC 4GB- RAM: 2x2GB+2x4GB DDR3 1600Mhz - Cooler: Corsair H80- PSU: Super Flower Golden Green HX Series 750w - Case: Zalman Z9 - Monitor: Samsung SyncMaster LD220HD -Speakers: Edifier 4.1 -Keyboard & Mouse: Microsoft & Hama Urage Illuminated
i have o.c. 8320 to 4.2 with currently settings
Cpu LLC : High
NB LLC : High
Cpu current cap : 130%
Dram: 130%
Cpu Multiplier : 21x
Bus Speed: 200mhz
Ht link/NB Freq : Auto
Cool&Quiet : Disable
C1E : Disable
SVM : Disable
Core C6 State : Disable
HPC mode : Enable
Cpu Cpectrum : Disable
Vcore :1.3V
Max Temp Cpu : 62 Celcius
Max Temp Vcore1 : 58 Celcius
i have ran prime couple times for 8 hours,and it seems stable BUT one time i noticed that from 4.3ghz dropped to 3.7 and 3.2ghz and other time from 4.3 to 4.1 and last time it didint drop...
on gamez some times drops from 4.3 to 4.1 and then 3.8...
these i have noticed from hwmonitor..
Also my temps on vrm are ok,it drops ghz for example while vrm temp are around 45Celcius...So it doesnt have to do with temps..
In HWinfo seems the sames values not at the same time...and noticed that multiplier doesnt dropp but bus clock of cpu+nb has dropped..
so my question is why?
i think that isnt throttling but i dont know the reason...
thought maybe is my mobo but i dont wanna to believe it...
do u have any idea?
i would like to note that there are times that while playing dont have any drop for hours but also there are times that in an hour can take me to 3.8 or 4.1...but i dont see any framedrop on gamez
P.S. power option in windows are set on perfomance
my specs are
Cpu LLC : High
NB LLC : High
Dram: 130%
Bus Speed: 200mhz
C1E : Disable
SVM : Disable
HPC mode : Enable
Vcore :1.3V
do u have any idea?
