I'm not 100% sure if this is the correct place but it seemed the best suited.
http://pcpartpicker.com/user/jonathantrillo/saved/3C0B
Basically since day 1 of this pc i have never been able to play HD footage properly. It'll play smooth only for seconds then the frame rate will just drop and it'll repeat.
I've tried everything I can think of, updated drivers all around.
I downloaded AMD overdrive. When watching 1080p on YT. CPU was at around 40%-70%, however the GPU would alternate from 0% to ~50% then spike to 100%. The graph it plots is just up and down all the way along and not a consistent line like the CPU which seems odd to me.
It's the same issue on Hulu, Netflix and YT. Can anyone suggest anything I could try?
