Oh Right, i forgot.
I have set everything back to normal, but i will Overclock it again and then send the screen shot.
Hi,
Im back, ok so i got your screen shots, iv used the pc so that you can see max and min values.
I needed to play a round of cod4 online...
Ok so attached are the images you requested, iv added the CPU-Z pic again as i took it after playing cod.
also please have a look at the first BIOS screen i sent earlier today ill tell u what is different now.
Multiplier on there say's 12X ( Mine only goes to 11X)
Other things i set are the "Chipset settings"
K8 to Frequency (4X)
K8 to LinkWidth ( 16 down 16 up)
SB to NB Frequency (5X)
SB to NB LinkWidth (16 down 16 up)
The 1gig sticks are Kingston
The 512mb sticks are GEIL
Thanks in Advance
One thing that might help is, not sure if you have ever seen the underside of the A8N32 Sli Delux.
It has a thick copper track on the bottom Left if i recall correctly.
Well when i got might that Track was burnt off, its been working for 3 months now (thats how long iv had it)
Only thing i can pick up is the 12volt rail or something like that has no reading, reports 0v in BIOS ( Hardware monitor) and Asus Probe.
Your only problem is your running too many sticks of RAM. 939 does not like that, puts too much on the NB. Pull those 512's and try again. The clock speed you gain will make up for the the RAM you pulled.
Hey Tweaker, tell me, is your copper strip on your board intact.
I'll just soldier a wire on mine then it will be good as new lol.
As for the Cooler, this is my second after Market cooler,
http://www.chaoscomputers.co.za/products/1733/?name=Hyper+TX3+CPU+Cooler
I will try those settings and let you know, just working at the moment.
Cas Latency 3, RAS to CAS/tRCD 3, RAS Precharge/tRP 3, tRAS 8, Command Rate 2Tweaker, can you just explain those ram settings please.
What must be what
Pull those 2 sticks and set your RAM to 4-4-4-12 2T. Socket 939 loves those timings.
Hi Guys, i havent tried anything else yet as iv been busy.
But why is my core 0 running much higher than core 1 ???
^^^^^^^^^ Look up ^^^^^^^^^^^^^^^^
could it be power ?
Could it be that Thermal paste has been applied wrong ?
Regards
Werner
