Ha so its a push and pull config like mine i have mine at the top of my case push n pull and a fan blowing on the mosfets and it keeps my 8120 4ghz cool at 46 c what voltage do you have yours at to get 4ghz??
Thats exactly what mine is mate im gona invest in a h100 try and get 4.5 or even 5ghz?does yours throttle when it goes over 55c mine does and i have everything turned to disabled aswell
Good luck with 5ghz. Mine used to throotle down to 1.4 ghz at high temps. I put a 80mm fan on the back of the motherboard to coll down the processor from the other end and now it doesnt
