alex561858
- Feb 17, 2013
was waiting for some time to upgrade from stock amd cooler to corsair h100i
after installation and and some set up i decided to give it a try and see how far this guy can go in clocks
Asus Crosshair Formula V z
amd fx8350
corsair vengeance 16gb 1866
cooler master GX 650
xfx 7950 dd ( not OC)
Win 7 x64
looked around and saw that mostly everyone sticks to 5Ghz
new fancy bios confused me so badly, but i finally found ratio and multipliers, voltage was tried in two combinations - 1.488 and 1.5v
ratio was left on 200 ( tried 215 but it affected RAM which i don't wana touch)
when it comes to multyplier it got dissapointing - i tried everything from x22 to x25
i boot insto OS but when i just start prime 95 it just hangs no matter what
i cried for some time and decided to go for AMD software.
waited for hours to test all the speeds.
CCC told me i'm good at 5.4Ghz, obviously it hanged
5.3 - hanged
5.2 hanged
and so on
http://www.overclockers.com/forums/oc_images/images/smilies/banghead.gif
tried amd stabilyty test instead of prime95 - no luck
so the question is -
WHY U NO WORK??????
http://www.overclockers.com/forums/images/smilies/rain.gif
http://www.overclockers.com/forums/oc_images/images/smilies/bawling.gif
would it be my psu????
cuz at the moment of building the rig i had pnly 1 4pin for cpu power
when MOBO had 8 pin and 4 pin ( i used half of 8 pin )
pleasepleaseplease advise!!!!!!!!!!!!!!!!!!!!!!!
amd fx8350
Win 7 x64
5.3 - hanged
5.2 hanged
and so on
WHY U NO WORK??????
