I would love a ssd but I need a large hard drive to store my video games and record videos and edit them so I am going for the 2tb drive. Next time I buy a upgrade I will buy a ssd then.
to that chris! I don't think I can use a pc anymore, without a SSD!I agree with everyone on the awesomeness of SSD's. It is actually painful to use a mechanical drive as anything more than just a place to dump large files.
Well then do that then... but also get a $50 128GB SSD to boot the OS from!I would love a ssd but I need a large hard drive to store my video games and record videos
Hello, new to the forum. First post in an overclocking thread. Background is with a 3 year old FX-8350 chip that has been overclocked to 4.4 GHZ. First two years at 4.2GHZ on air with Hyper 212. Last year at 4.4 Ghz on H105 AIO watercooling. Will upgrade to a FX-8370 tonight that I just received. I believe that the FX-8350 was damaged during the first two years on air cooling. Never had an issue till the last couple of months with errors on SETI CPU tasks with what appears as a bit-flip. Finally got around to trying Prime95 tests and found it failed immediately on Core#5. Have tested the RAM many times now with MemTest86+ with no errors so deduced that the CPU was causing my CPU errors on my SETI tasks. Downclocked the chip back to stock 4.0 Ghz and can pass Prime95 Blend and Small FFT tests for several hours with no errors. Will start stock clocks and Prime95 to verify the new FX-8370. Then attempt to move on to an overclock at least equal to what the 8350 was doing before failing. Should I attempt to try the 4.6-4.7 Ghz speeds that I see have been reached on watercooling in the many threads I have read today? I have also stuck a 50mm fan on the backside of the CPU socket to cool the socket temps. Made a big difference on temps but unfortunately did not help at all with the overclocked 8350, I guess the damage has been done. I will keep that configuration with the 8370 since I will try to overclock that eventually. I need stable running producing no errors on distributed computing projects SETI@Home, MilkyWay@Home and Einstein@Home. The system is loaded 100% for 8-10 hours during the summer and 24/7 during the winter. My other system is basically a twin of this one except a year newer 8350 that runs 4.4 Ghz at stock VID. A better piece of silicon than the failed 8350 which runs at .08V less VID. I'm hoping I won the silicon lottery with this new FX-8370. Comments about my aspirations?? Thanks in advance.
I'd start a new thread to get more answers
Also, sounds like you needed just a bit more Vcore on the 8350, and overclock in steps with the 8370 (or any CPU for that matter) raise multi, prime95 if pass, raise multi and test again if fail, raise Vcore and test again.
Wash, rinse, repeat.
to OCF Keith!
I forgot to add the reason sanding the heat sink works is because of cooling and heating up the heat sink can warp and bend. By sanding it your flattening out the bottom again.
