stickyfingazz91
- Jun 20, 2012
Hey guys just wondering if 64 deg C is norm for cpu temp after running prime 95 for 17 minutes with the h100 hooked up and ambiet temp of 24 deg C. I currently have it overclock to 4.5Ghz with a Cpu voltage of 1.34V and multiplier @22.5 and bus of 200. The motherboard is sabretooth 990fx. I do have the h100 in a push and pull and I also added 80mm fan next to the h100 as you can see from the pic(this helped lower the cpu temp and vcore by roughtly 10 deg C. Also do you guys have any other suggestion on what I could do to lower the cpu temp?
