Hi guys I have a problem with my cpu In practice, I changed case and reassembled everything, in doing so I had given the gpu a repaste , but the cpu practically did not touch it (so it remained with the heatsink attached from the other case), when I go to reassemble everything I do a cinebench and everything is ok as always with the cpu, then I start a game and the temps of the gpu skyrocket, I practically realize that I was wrong to repast the gpu (I put some liquid metal), I put too little paste, then I have practically disconnected the pipes of the gpu only and removed only the gpu to ripaste it (losing part of the liquid of course), then I put the gpu back, reconnected the pipes, filled the loop, and now it is the cpu that has problems (why ??? I have not even touched it), the gpu has temp divine (40/44 degrees in full load), but the cpu behaves strange, in idle temp in the norm (32~33 degrees) , in game I would not know but I would say yes (I'm playing Gears 5 and the cpu is about 50 degrees, now I do not remember how it was before, but more or less I think we are there), I made a stress test with cpu z and temperatures are in the 80ties (perhaps already higher), but it is with cinebench that we are not there, in practice I register an increase of almost 10 degrees, touching 100 degrees on a couple of cores and on 94/95 on the intermediate cores and others on the 88/90 while before I had on average about 10 degrees less, and moreover it records me lower scores (probably because it goes into a slight throttle), but what the hell happened? Any problem with the liquid and the loop when I reassembled it? In fact I have a flow meter and it runs quite slowly but I don't know, but the gpu has no problems, what the hell happened?
