- Thread Starter
- #41
New update
I thought I was good to go with this board. A new board solved the constant C1 memory errors. I was running stable w/o OC'ing and finishing putting together the system.
Then I discovered that my SATA drive had very poor performance (4MB/sec speed). I only use the SATA drive for mass storage. I have 2 SCSI drives which I boot off of and contain most of my files. After some work, I found that the SATA port I had the drive connected to was bad. I swapped ports and the HD speed jumped up to 60MB/sec at the front of the disk. I haven't tested all of the SATA ports yet but with at least one bad one, I now need to RMA this damm board again.
Additional issues I encountered include the uGuru utility crashing at startup until I installed the latest beta version. Also, uGuru does not read the CPU core temps correctly for (at least) Intel G0 CPU's. The temps are 10-12C under actual. Not sure if they can fix this with a BIOS change or if a physical board revision would be necessary. Also, the erroneous low CPU temp readings screws up the ability dynamically manage the fans through the settings in the uGuru and the BIOS.
Then I've found that those side mounted SATA ports are a real pain to plug anything into (at least with this CM690 case).
I've sent 2 emails over the last 2 weeks to Abit technical support and have yet to receive any acknowledgement or reply. On the Abit forums, there are others with a variety of strange problems with these Abit IP35 boards (and that is of course, only the ones who go to the forum for solutions).
With my experiences so far (and what I have been reading on the Abit forums), I would be hard pressed to recommend Abit the company or the IP35 line to anyone.
I may be stuck with this board or I may be allowed to exchange it for something else from where I purchased it, which I would be leaning to at this point.
If I can exchange it for another brand, can anyone point to other high-end boards which have at least these specific functionalities?
1. The ability to clear the BIOS w/o opening the case
2. Very good OC control from the BIOS
3. The ability to save BIOS versions and reload them as necessary (this board can save 5 versions).
4. Plenty of fan headers (the IP 35 Pro has 6 total fan headers)
5. Good technical support
Just to update: I RMA'd the board back to MWave. They replaced it with the newer 1.1 revision. Everything is working now and hope to get the OS loaded & configured this weekend.
