- Nov 14, 2009
- Great North
Your stock core clock is 200
Your stock multiplier is 16
And I'm fairly sure your stock voltage is 1.4v
I'd just move the multiplier.
Bump to 16.5, stability test.
17, stability test (now you're a 965)
17.5, stability test
Repeat and find your highest stable multiplier (watch your temps)
then i'd start bumping the core clock a few MHz at a time, and running stability tests, try and find your Max.
Right down your clock, 205X18 or whatever it may be, and the voltage (1.4 or whatever)
then drop everything to stock, and bump your voltage one step (with voltage at 1.4v just press + on your number pad)
Repeat the whole thing, starting with multiplier, then core clock, always running stability tests. One you get as high as possible and still stable, write that value down along with your voltage.
Repeat that until you have 4 or 5 set, or until your processor is getting too hot.
If your processor is getting hot, there's no way around it other than a better heatsink (lots of recommendations in the cooling area)
Once your have 4-5 sets of data, plug it in to excel (or a graphing calculator) with one column being your total clock (the 3.2 out of 200X16=3200) and the other your voltage.
Use that software to find the pertaining non-linear relation, (may be quadratic, may be a little more complicated) then find out when your processor stops getting a useable boost per voltage step.
If you manage to get to that point without heating, it's not very useful to go much further, unless your gonna be doing some heavy-duty coooling (DICE LN2 etc.) and those won't get you a 24/7 OC anyways.
