hazzleraflet, it would be a courtesy to those helping you if you were to take the hardware info you supplied in the previous post and create a Signature so that it travels with every post you make. That way, every contributer has ready access to the system component info without having to hunt through the thread for it. The Sig tool is found by going to Settings and then looking down the left had margin for "Edit Signature." Add info about case and OS please.
As far as your core unlocker issues, I would clear the cmos with the jumper to reset the cmos. If that didn't cause the setting in bios to report correctly, I would try updating the bios.
