Hi, and its 1st post. Hope I can find help here and I hope I ask the right question.
Setup. MSI 590 gaming plus/ cpu i11600k/ Currently 16gb of crucial ballistix max 4400hz./ lastest bios/ win 10 but currently win 11.(fault occurs/exist with both )
Anyway the issue is if I try to run mem at 4400 at its timings 19.19.19.46.. the pc can crash either freeze in 30 seconds or 30 hrs. if i run it at 3600hz (16.16.16.36) its runs rock solid. But as it was bought as 4400hz and crucial says it should.. looking for answers?
the settings I've seen say try alter are the voltages SA/IO (are these the ones tha appear as cpu sa/io?) i can find my way around bios but don't really like changing that much to do with voltage. Also, when it boots at 4400 .. cpu z always reports it using 1.5v instead of 1.4v is that ok?
I also had a second kit of 4400 bought for me...(i know 2x16) would have been better, but there you go... that crash still occurs with new memory so that rules out mem prob..
Could anyone please give me a safe manual settings option to try in bios for this memory or is running a 3600 just the safer option and there's not gonna be much of a difference. If someone tells me that, ill be happy
cheers
Geoff
does that look about right for dropping the speed down to 3600 for a rock solid system. ... or having it all on auto there look bad?
still looking to get it to run at 4400 tho...
cheers
Geoff
