Thanks for your sharing , to be honest , i am one of those peple who is not familiar with burnning an iSO files to USB drive .
Johan could you advise if this method will work for Rog Strix B450F and Ryzen 3600x.
I just bought the upgrade hardware 2 days ago, all excited assembled into my old case. I have a Samasung 970 evo SSD nvme m.2 that has my old OS WIN 7 pro install on. Made a backup image just incase it went wrong ( things do ) and I know its not the right way guys but Ive been lucky till now.
Ive had the same install running on 3 builds to date with hardley a problem ever in the last 3 years. 8150 cpu on a gigabyte m5a78lmt usb3, then swapped into a asus 990fx r.3 sabertooth and 8350 cpu, even swapped a clone os back again with no issue at all, but I digress.
I hit the NO USB 3 suport issue and was thrown because it worked in bios right?? Anyway the board has a ps2 port so I can use a keyboard OR a mouse but not both. The system booted from my nvme SSD and works but there are missing drivers reported in Device manager.
I like the idea of streamlined OS, Updates and Drivers but Im not sure what drivers I should be including, also Ive read the chipset drivers MUST be installed before the usb drivers so Im a little overwhelmed with it all. Ive resigned to doing the CLEAN OS install that ive put off for like 2 and half years
Also it normal for NTlite to trigger Antivirus saying its trying to modify FAX.dll or something like that?
Ive read some posts from people claiming to have found a workaround but I dont want to spend a load of time trying an unknown fix and WONT be going Win10, Ill sell the hardware first! Sorry so many questions.
Here's hoping fingers all crossed etc.
