mjw21a said:Is anybody listening to what is being said here. As mentioned by Zac42 and DanIdentity, HyperTransport links have no impact what-so-ever on memory bandwidth/performance.
The memory interfaced directly with the integrated memory controller on the CPU, there are no additional links involved. The only area where HyperTransport links affect RAM performance in in a multi processor system where the memory controller of one Opteron requests some data which is held in a memory bank belonging to another Opteron processor. Hence it requests the data from the memory controller on the other Opteron via a HT link and recieves the data back in the same way.
CandymanCan said:TCCD wasnt even out when i got my A64 4-5 months ago, everyone or most people said to buy some BH5 ram or something that can run with goo timmings cuss 1:1 ratios didnt matter anymore. I didnt listen and got some pc4200 cuss it was dirt cheap only $120 from KOMUSA with ADATA ram and it paid off.
I know what you mean tho
CandymanCan said:To a point, yes, but running LL @ like 240MHZ wont beat anyone running 270+ with high Latency's like i am running.
I already knew this, HTT doesnt affect anything
X-actlymjw21a said:Is anybody listening to what is being said here. As mentioned by Zac42 and DanIdentity, HyperTransport links have no impact what-so-ever on memory bandwidth/performance.
mjw21a said:I don't post everything just for your benefit though Candy. I already know that you have a good knowledge base.
Obviously the topic needs some clarification for some people else the thread would never have been opened in the first place.
As a matter of fact I wasn't even replying to your post, you just posted whilst I was entering my post is all.
CandymanCan said:Never said you posted that or me anyway, i was just letting you know i already knew that
oc_byagi said:Sooo.... what this thread was trying to say is invalid right??? I was just getting confused.
deception`` said:OC-Master is complaining that a) reviews are never done using the 1000/5xHTT and b) are still benchmarking using DDR400. I, on the other hand, argued that these were a necessity as to provide a level playing field in terms of comparison.
deception``
CandymanCan said:I tend to say things like "i already knew that" alot tho, my fault
oc_byagi said:Ah, I see. Point A was explained by those others who have already explained for us, that it has no effect in performance
For the point B, why would reviews use DDR 500 when all the other reviews for other systems are using DDR 400 as well??? Only place that may require reviews to use DDR 500 is when they test overclocking. Potenial in performance boost is similar for all the platforms, it is not necessary for the reviewers to show the full potential of the component they're testing, even though it would be much helpful.
mjw21a said:Sorry mate, I tend to take offense too easily sometimes. I thought you were indicating that the post was pointless, as it contained no new info for you.....
I do believe that AMD should state support for DDR500 though as often times sites will simply benchmark the top of the range Intel platform vs the top of the range AMD platform. Offering DDR500 would obviously give AMD the upper hand, although they already have that don't they?
OC Detective said:Did AMD ever publically come out as say they would make DDR500 an official standard when they first talked about 939's? Not saying they didnt - just dont recall?
deception`` said:Maybe so, but DDR400 should be compared to DDR400, period. Granted this dilemma is only colluded when it comes to DDR2 systems, but we are all WELL aware that DDR2 is so bogged down by it's terribly high latencies to the point that it nets no gains, whatsoever.
deception``
mjw21a said:I agree that the same memory types should always be compared, but there are many people (the majority I'd say) who simply buy, and keep their systems stock. There are also a number of people in this category who wan't the fastest system available regardless of cost. Going DDR500 would allow AMD to cut down their cache size a little and probably increase their overall PR rating. Good for sales and better margins per CPU sold.
The situation will change either when lower latency DDR2 becomes available or simply when higher frequency DDR2 becomes available. Personally, I'm not a big believer in DDR2 tech. The industry would be better served by moving to QBM or XDR memory....
deception`` said:DDR2 is no different from RDRam to me; both possess extraordinary bandwidth potential but ridiculously high latencies. Intel tried to make Rambus work, but to no avail. So you could understand just why I am not enthusiastic about it whatsoever.
deception``
