O OC_KING Registered Joined Feb 26, 2005 Mar 3, 2005 #1 I can open the bios for p4p800 deluxe and if i change the value under " string" will the value be effective ? i change the Vdimm value from 2.85 to 3.2 but i didnt flash the bios yet. will it works if i flash the bios ?
rhino56 Member Joined Dec 11, 2003 Location Arkansas Mar 12, 2005 #2 id like to know when you try it if it does.
