- Apr 19, 2012
After installing my new H80i cooler I have noticed the temps to be somewhat high idle they are around the low - mid 40s and under load with prime95 they will hit the high 70s. With programs I use on a regular basis they will push the CPU to around 50-70% load and give me temps in the 60s. What could be the cause of this?
Specs
Asus P8 Z77 V-LX
Intel i5 3570K overclocked to 4.2ghz
corsair H80i fans set to pull air from outside
front intake fan and top exhaust fan.
Aftermarket thermal paste used Arctic silver using the blob method, heat block is not loose fastened correctly (corner to corner)
Hopefully I provided all the extra info you guys would have asked.
Specs
Asus P8 Z77 V-LX
