Greetings from the noobest noob to liquid cooling. I have been gradually gathering the pieces to build a new system and decided to go with liquid cooling. I have read quite a few things in these forums about the pros and conns of various setups/parts/kits and decided to build it piece by piece rather than buy a ready made kit.
Here is a list of what I have so far:
Case: Thermaltake Mozart Tx VE1000 (Nice and huge so everything will fit inside with no problem).
Swiftech MCP655 pump with speed control
Bitspower water tank z-multi 400 reservoir
Danger Den MC-TDX cpu water block
2 Swiftech MCR220-QP dual 120mm radiators
Swiftech MCW30 chipset water block
Danger Den 8800GTX video card cooling block
Enough 3/8" ID barbs, clamps, and tubing to get the job done
My questions are:
Tubing:
I have 2 different sizes of tubing I can use. PrimoChill Clear 3/8" ID 1/2" OD or UV Blue 3/8" ID 5/8" OD. About 15 feet of each. Also have anti-kink coils for both sizes.
Would like to know if it is better to go with the thicker tubing?
Coolant:
I have some PC Ice with optional UV Blue die bomb. I have read a few things where the dies can cause some problems with junk accumulating in the loop. Of course, if I use the UV Blue tubing then the die is kind of useless. If I use the PC Ice, I will need to get more since I only have 1 bottle and it does not look like it will be enough to fill everything. I also have some PT Nuke and a Silver Kill Coil.
Should I go with the PC Ice or use distilled water instead?
Can the PC Ice be mixed with distilled water and used without any problems?
Since all of my water blocks are copper and the radiators are copper/brass do I need something to prevent corrosion? If so, what? Preferably something other than antifreeze and not poisonous.
The Loop:
What would be the best order or layout to connect each piece together?
Res >> Pump >> ? >> ? >> ? >> ? >> ? >> Res ???
Will the MCP655 be able to handle it or should I add another or get a bigger pump?
Should I use a single loop or make 2, 1 for CPU and Chipset and the other for the video cooler? Can the pump handle 2 loops or should I have a pump for each loop?
Any help/advise would be appreciated.
My questions are:
Tubing:
Coolant:
The Loop:
