- Oct 29, 2012
Good to know! Prime95 is still chugging away almost an hour later. Max temp in HWM was 56ºC during those 800,000k tests but it only peaked there. It hovered around 53-54ºC in those tests after peaking! I may try and go up more... we'll see! Of course my HTlink and CPU-NB frequencies are at 2000 so that may be part of the reason why I'm not having issues. It seems like anytime I go up on those above 2000 I get rounding errors galore in Prime95, even with tweaking voltages.
It would be better to run something like 3.65 or 3.7 core and 2600 on your NB if you could help it. HT doesn't matter, 2000 or match NB doesn't seem to change much on these parts (I typically try to keep it around 2000 on Deneb, just a superstition of mine). You'll definitly notice higher benching scores if you can get a stable OC around your settings WITH a 2.6~ NB. The C2 controllers are weak, so going much higher can be a bet meh. I could get my own C2 up to 2830 ish, but it required more effort than it was worth
