- Dec 20, 2002
- Long Island, NY
Hi folks,
I was getting ready to place an order with Newegg for some components I need for my new build and noticed the specs on the video card I wanted. It's the eVGA 256-P2-N624-AR GeForce 7900GS 256MB 256-bit GDDR3 PCI Express x16 KO and the minimum system requirements as listed are as follows:
Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 20 Amps.)
Minimum 500 Watt for SLI mode system.
(Minimum recommended power supply with +12 Volt current rating of 28 Amps.)
An available 6 pin PCI-E power connector (hard drive power dongle to PCI-E 6 pin adapter included with card)
The Antec power supply that I already purchased and installed in my new case, I actually thought was more than enough power considering I only intend to run one GPU, since I'm not big into games. The 7900GS is just within my budget for a decent video card.
But the Antec Trio TP3-650 only supplies 19a to each of the 3 separate 12-volt rails. Obviously 19a is not 20a that is recommended. Did I just waste my money on this power supply? I purchased it because it's supposed to be a well made and quiet PSU, which is very important to me.
The new build will consist of the following components, only the case, power supply, and LCD monitor have I already acquired.
Antec P160W Anodized Aluminum Super Mid Tower
ABIT AW9D-MAX
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive
Samsung 225BW LCD Monitor
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
LG 16X DVD±R DVD Burner With 12X DVD-RAM Write and LightScribe White IDE Model GSAH10LI
Windows XP Pro SP2
Can anyone give me an opinion whether this system will work with this PSU? Thank you.
Richie
ABIT AW9D-MAX
Windows XP Pro SP2
Richie
