I've seen the p180 mini case, and while the actual top fan is relatively quiet, high rpm are required for gpu/motherboard/cpu. With hot components, I think airflow from the bottom up is better for a quieter system.
Ideally I'd like airflow to be something like 2x NZXT 200mm case fans blowing up with very low rpm fans for mobo/northbridge, gpu, and cpu (possibly a corsair H100 for cpu). System will probably be along the lines of i7-2600 with slight overclock, and GTX580 or Radeon6970 level gpu (mostly depends on what has the quietest cooling available). Any suggestions? I'd prefer avoiding a custom made case.
