anyone in usa have a PCI-E 8 pin to 8 Pin PCIE cable for a thermaltake 1350m PSU?
leo5111
anyone in usa have a PCI-E 8 pin to 8 Pin PCIE cable for a Thermaltake Tough Power 1350m PSU? id pay you for it....as mentioned its a Thermaltake psu the Toughpower 1350M
yes but on the PSU its in red section its a 8 pin that goes into red section which says "pci-e" and then a 8 pin or 6+2 that goes into video card..EDIT see red section? they are 8 pin and says pci-e... i have one of those cables its red on each end and 8 pin
Yep, that's the end for their PSUs.
I know you can order cables directly from TT (or custom ones from cable mods). If nobody chimes in, consider that.
That thing comes with, six............. lol! Did you lose a few? Also, what are you powering with a 1.35KW PSU? No system you've discussed uses more than 300W, lol!
EDIT: Did you buy this because you thought your 850W wasn't enough??!!!
moved and cant find little bag they were in funny thing is i know 100% i took it with me, i searched every drawer/closet in my place to make sure nothing was left behind
its not the same only came with 2 of the red pci-e cables
What isn't the same?
I didn't suggest or allude to using the cables on the 850W. In your last thread, you were asking if you had enough power out of your 850W PSU, and now this thread. Perhaps they are unrelated, but figured I'd ask.
i miss read what you said..oops...sorry but ya i emailed themaltake i was hoping someone hear would have a dead tpoughpower and want to part with one the cables or thermaltake would send me one but if not ill have to order a 3rd party one off amazon
Post magically merged:
i decided to return the other psu to bestbuy since this one works fine just need pci-e cable
