- May 10, 2002
- AL
I'm still dreaming of a Core 2 Duo level jump from Intel...I said dreaming ok?
Same here. The brand that I buy into depends on the total cost of that eco system. CPU, RAM and MB. The rest is interchangeable. For now I'm AMD because they gave me the most for the dollars I was willing to spend.I go where the performance goes.
Thing that pisses me off with Intel is the change in sockets & chipsets nearly with every generation. However it has been a bit surprising to see LGA 1700 having the life it has so far. But the end of the road now with raptor lake refresh. So this lead me to AM5 socket, of course according to AMD so far support until 2026. Also the lower energy requirements are a nice thing too of course but the heat density & the thickness of Zen 4 IHS is a the bug in the pudding imo. If it wasn't for undervolting via CO, their products would be a toss up between them & Intel in 2023.
No argument there but it becomes a bit of "lesser of 2 evils" kind of thing doesn't it? I mean both companies have a monopoly on the x86 market, so the rest of us DIY enthusiasts just have to 'suck it up' as they say....If you look at AMD, then they're not any better. The same socket for longer, but each new CPU has different requirements. You could see that especially in AM2/AM2+ and AM3/AM3+ when some CPUs were compatible, some not, and some required stronger power design. Ryzens are, in theory, compatible, but there were big problems with newer CPUs on older motherboards, or support was added with a huge delay, so most of those who wanted only the new and faster CPU already bought a new motherboard. AMD failed most premieres of CPUs for existing sockets (this is a long topic, so I will skip it). It wasn't so bad if the motherboard was from a high series. If it was from a low series or less popular, you could wait for long months for a proper BIOS without significant issues. I say it's AMD's fault as they always provide firmware less than a month before the premiere, so motherboard manufacturers don't have enough time to fine-tune or add anything other than support for new CPUs ... so they could start not to work optimally.
