- Jul 12, 2007
APEVIA FC-01 Multi Fan Speed Controller
I'm considering purchasing this product because it is a PCI slot fan controller that uses molex connectors so from the back of the computer which is more convenient for me I can reduce the noise of three 120mm case fans with just one of these.
My case fans are:
1.) COOLER MASTER R4-L2R-20AG-R2
Rated Voltage: 12 VDC
Current (Ampere): 0.35A ± 10%
Power consumption: 4.2W ± 10%
LED lights have been manually cut
2.) COOLER MASTER R4-L2R-20AC-GP 120mm Blue LED Case cooler
3.) Unknown brand 120mm clear fan. Does not run loud at full speed.
Before I pull the trigger I was wondering if there are identical/similar alternatives that are better. Please keep in mind I can't use one that sits in the front bay or uses 3-pin connectors.
You could also chime in your experience with the APEVIA FC-01 Multi Fan Speed Controller.
My case fans are:
