Hi guys,
Recently I started to build my workstation. And right now I run into the next issue:
1. Firstly, I can't find any info about compatibility Aquacomputer 6 XT with Thermaltake Pacific DIY LCS PR-22 D5 pump. Can I connect this model? As far as I understand the major criteria in this case - that this D5 pump. But I can't find any info about PWM specs for this pump.
2. Secondly, I plan to install 2 calitemp, 2 high flow, and 2 pressure sensors (Delta 1000). Hence, I need to clarify next moment: do I need to install aquabus X4, or I can plug these sensors directly into Aquacomputer?
