Anyone here have Aqua Computer's Aquastream Xt Ultra pump & the aquaero control monitor can please explain to me what get connected on the back of the Aquastream Xt Ultra pump & how it works with the Aquaero control monitor. I can not understand the connectors & what each one is for on the back of the pump.
About the connectors on the back of the pump Aquastream Xt Ultra. What are they for & how does it work?
"Ext. Temp" <----- What is this? Is this for connecting a temp. sensor to a cpu or gpu water blocks or something else...? would you connect it to the Aquaero control monitor?
"Aquabus/flow" <---- I don't know what aquabus is. What is it? I know flow as in a flow meter that gives (indicates) the flow rate or shows the flow pressure maybe? Wouldn't I connect the flow meter directly to the back of the Aquaero?
"Fan" <----- is this what you connect to the Motherboards CPU fan only. A direct line so that when theres a problem with the pump it can directly send a signal to the motherbord that turns off the computer (telling it ) by stopping the PSU. all together. Acts as a kill switch, right?
"RPM" <---- I dont understand why you would have this connector? and being Externally? I think is this for cheeking how fast the pump is going. revolutions per minuteIs this the speed of the pump you read in the aquasuiite softwares control panel only? I would think you'd get this information by it going thru the usb connection.
