- Apr 20, 2006
- Gilbert, Arizona
- Thread Starter
- #41
CRAP! Alright, I hooked up one quick connect to a pressure guage, and the other to my air compressor, to see if it leaks, and it started hissing right away. The loud thing was the center input barb of the RBX CPU block, I had to take it out and I got a different clamp, problem solved. I pressurized it again, and it was looking good. Then after about 5 minutes i looked at the guage, I started at 8 PSI, now it was at 5. So i busted out the toothbrush with soapy water, and it is the outputs of both radiators, so I need to take them off and retape them, then see if it works, if not i have teflon dope, that should fix it.
Trying to get this done, I'll update tomorrow, any replies within like 20 minutes and I'll get to them, if not, talk to you tomorrow.
