- Feb 18, 2007
Nobody cares.I built a 5.0 GHz version of the i9-9900KS into a thinner form factor that fits into a stainless steel briefcase. It's basically a laptop that needs constant AC power, but you can close the lid and take it with you. I put analog temperature gauges on each side of the handle so you can see the temps without needing to launch a software utility. The power cord retracts on a self-capturing ratchet wheel. There's no way in hell I'm uploading that build log here now.
Don't be so easily offended. You build a nice DIY case. Something to be proud of. If someone shows you an example of a commercial success it is not a put-down. If anything, it should inspire your creativity.
