Hi just overclocked my AMD FX8120 to 4.1GHZ and ran prime95 for 60mins,all was stable no errors & no warnings have a screenshot of the temperature below do thay look ok? or are thay to high.dont know what the max temp is on this cpu,any info would be great.
Did you take the screen shot of HWMonitor during the Prime95 stress test, before, or after? The reason I 'm asking is there is almost not variation in the temps from max to min like you would be if HWMonitor were open before you started Prime.
My cooling system for my CPU is a moded Corsair H60 configuration is as follows
1...outlet from reservoir to inlet of H60 block & pump
2...outlet from H60 to H60 120mm rad (push/pull config)
3...from H60 rad to 240 rad
4...from 240 rad to inlet of reservoir
The red arrows the air flow of all fans in the case
