wataru junior
- Oct 28, 2015
Hi all.
Not sure what happened to my GPU.
I was overclocking my Nvidia 820m. I set the graphic clock from 625Mhz to 800Mhz (actually it's detected 720Mhz Min and 954.6 Mhz Max) and memory clock from 900Mhz to 1080Mhz. I was using Nvidia Control Panel and Asus GPU Tweak.
And then when I was playing game, for a while ( around 1-2 hours ) everything run well. Temp max is 74 C. And then I tried to raise the memory clock to 1100Mhz ( 2200 Mhz effective ) to get better FPS ( I thought ). Run well to for a while, but suddenly the clock drop fro all things. Graphic, Memory, Shadder core drop to below default clock. I really don't know what happened. I thought my GPU crash. So I try to put the clock to it's default clock, nothing happened. And then I restarted my Laptop. And it's back up normal again. So, what was happening to my GPU? Is my GPU damaged ?
Thanks for any advances.
