On nearly all X299 motherboards, processors OC the same. Even on these cheapest can make 5GHz+ and if you won't OC on LN2 then max clock under higher load will be still below 5GHz. Even on the ITX motherboard, I had 4.9GHz on water. About the same was on ASRock X299 Professional XE, ASRock X299 Killer (with single 8 pin power connector), ASRock X299 Extreme4 or something more exotic like Supermicro. Simply your clock will be limited by cooling, not the motherboard.
@trents, no matter what ASRock uses (there is not only one design), their motherboards are usually better than anything that competition offers. I've never had issues with power section of ASRock motherboards while I killed many Gigabyte, some MSI and some ASUS boards. I guess you know that ASRock is a good option as you use it and recommend to other users
On new motherboards, power section is not really a problem. Most boards are much stronger than it's required. It's just that marketing says we need 2kW power to overclock i3 CPU and later people spread that around the forums.
The main difference between motherboards is on LN2 because of additional options like low clock boot or anything else what helps to start at low temps. Also memory is overclocking better on these higher OC motherboards but processors not really. I could still hit IMC limit on at least 4 X299 motherboards.
If I had to pick one of these 2 motherboards in post #1 then I would probably buy the APEX. These mobos are great and ASUS cares to deliver the best support for top ROG series. On the other hand I would buy it more as a toy than a motherboard which I was use 24/7 in my gaming PC. As I already said, if it's for some benching and later mostly gaming then better save some money and get a cheaper motherboard.
