Hello everyone! I recently put together my first PC build using an Asus Rampage 3 Extreme Mobo and an Intel i7-970 CPU. (I will list the build specs at the bottom of the post) I was given the Mobo and CPU from a friend and was lucky enough to find just the right deals on the rest of the build to make this a very cost effective build. I am happy with it so far but there are a few things I am considering adding onto this build being this mobo is older and lacks some of the components that newer motherboards have and that i would like. I have done a good amount of research but i am a bit confused and overwhelmed at which components i should get, being why i am here. Hopefully i can get some good insight, direction, and recommendations of which components would be the most cost effective as i am on a tight budget at the moment. Anyways, enough blabbing and lets get to the questions! The first component i would like to get is a Sata 3 Pci/Pcie card. I am using the intel ich10r sata2 for both boot and data disk. I have not seen a huge difference in performance with the intel ich10r and the marvell 9128. From what i have learned the marvel 9128 is PCI Express 1 and is not even really a true "SATA 3" controller. I am currently not running any raid arrays but in the near future i would like to purchase another ssd and run raid zero array's with my ssd boot disk. With that said, which PCI/PCIE card should i look at purchasing? I have looked at ones that were 20$ and looked at ones that were 500$ plus. It seems the ones that were cheaper did not have Raid capability and i was confused as to which ones i could boot up off of and that were compatible with my mobo. Am i going to have to spend hundreds of dollars for a Sata 3 Pci/Pcie card if i want to run a raid array and boot off of? Here are a couple links of the two different ones i was looking at. https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.... & https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334.... Would the cheaper ones work for booting an ssd in sata 3 on the R3E? I assume the cheaper ones would not allow raid arrays as well? I would like to find the least expensive one that would work for my setup and what i am wanting to do. Also, i have read that you can use the Samsung evo 850 Nvme as a boot drive on this motherboard. What exactly would i need to be able to do this. I would assume there is an adapter or component that i would need to be able to boot off of a Evo 850? This link explains what i was thinking of. https://www.overclock.net/forum/20-hard-drives-storage/... The second component i would like to get is a USB 3.0 controller/header so that i can use my USB 3.0 plug ins on the top of my pc case. The R3E only came with one 2.0 header and I am currently using that for my Corsair h110i GT AIO Cpu Cooler. Here are a couple examples i have looked at https://www.nzxt.com/products/iu01-usb-expansion & https://www.ebay.com/sch/i.html?_from=R40&_nkw=internal.... Which one would be best for my setup? I noticed there are some that use the existing 3.0 mobo header which the R3E does not have, so i wont be able to use those ones... The other style seems to be a pci/pcie card and i noticed some of them have headers and extra usb 3.0 ports on them and some of them just have headers or just usb ports. My pc case has 2 usb 3.0 plug ins on the top and 3 usb 2.0 plug ins on top. There seems to be different model numbers as well? Some have an "J8Y8" or "H5Y2" at the end? I am super confused as to which one would be best for what i am looking to do? For the 3 usb 2.0 plug ins on top of my case, would i have to get another pci/pcie adapter card just to use those ones being that my only usb 2.0 header is being used by the Corsair AIO? The last thing i would like to get is a wifi card? I am super lost as to which one i can use for the R3E. Just like the Sata 3 and USB 3.0 cards, there are millions to choose from and i dont know which one would work for my setup? If you have read this far i Thank You Kindly and apologize for such a long post but wanted to make sure i gave as much detail about my questions so that i could get the best recommendations and help! =) I will list my pc specs etc down below. PLEASE HELP!!! =O
Mobo: Asus Rampage 3 Extreme Edition
CPU: Intel i7 970 Model:C Ext Model:2C Family:6 Stepping:2 Revision:B1 Overclocked to 4.5ghz @ 1.43v
Power Supply:AeroCool XPredator 750GM
PC Case: Rosewill Rise Three 120mm intake Fans In Front, One 140mm Exhaust Rear, One 80mm Exhaust Rear, Two 140mm Fans & Raidator Up Top Inside From Corsair AIO Cooler Exhaust, One 120mm Exhaust Bottom From PSU
CPU Cooler: Corsair H110i GT AIO
Ram: 24gb (4x6) 4gb g skill f3-12800cl9d-8gbxl with Corsair Dominator AirFlow Fan On Top
GPU: 2 (SLI) Asus Strix OC GTX 960's 4gb Vram Each
Hard Drives: San Disk SSD PLUS 248GB (The Newer Version) OS - Seagate Barracuda lp 2tb st2000dl003 5900 RPM Data - western digital wdezex 1tb 7200 RPM Data
