- May 7, 2012
- Dorset, UK
I'm going to be upgrading to a ASRock Z77 Extreme 4, i5 3570K, and Thermalright TRUE Spirit 140mm. My case is a Zalman Z11 Plus which is only wide enough for the height of the true spirit under the side window as it bulges out.
Can anyone tell me how far the CPU socket is from the top of the motherboard so I can check if it will be low enough to be under the window?
Thanks in advance.
Thanks in advance.
