Can someone review my settings and make recommendations and/or point me to any high overclock bios templates? Atm am running a 2600k under ss phase (vrm/nb under water). Run 54x, 100BCLK no problem and have BCLK up to 108 (35x). Have gotten 5500 but trying to push a little further (so am in ok boints-land)...ideally would like to get to whatever max I can hit with the board as I'll be using it for a number of other cpus.
Am also wading through the over 275 page thread at OCN but haven't been able to find what I'm looking for yet. http://www.overclock.net/t/1254599/official-asrock-z77-discussion-owners-club
Also...anyone know if setfsb or clockgen work with this board? Anyone know the PLL?
tia for any guidance!!!!
NickShih's OC Profile- default
OC Tweaking- disabled
LN2 Mode- enabled
Super Pi 32M Tweak- disabled
CPU Ratio- all cores
All Core- 54
BCLK- 100
Spread Spectrum- disabled
Intel Speedstep- enabled
Intel Turbo Boost- +0.039v
Additional Turbo Voltage- enabled
Int PLL Overvoltage- enabled
Long Duration Power Limit- 4095
Long Duration Maintained- 128s
Short Duration Power Limit- 4095
Primary Plance Current Limit- 1023
Secondary Plance Current Limit- 1023
GT Overclocking Support- disabled
Load XMP Settings- auto
DRAM Freq- ddr3-1866
DRAM Timing Mode- performance
DRAM Config- manually set to 9-9-9-24, Command Rate=auto
Power Saving Mode- disabled
Extreme Voltage- enabled
PWM Switching Freq- 600k
PWM Curr Threshold- enthusiasm
CPU Voltage- fixed
Fixed Voltage- 1.68v
CPU LLC- level 2
IGPU Voltage- auto
IGPU LLC- auto
DRAM Voltage- 1.65v
VTT CPU 1 Voltage- 1.141
VTT CPU 2 Voltage- auto
VCCSA Voltage- 1.153
VTT DDR Voltage- auto
PCH 1 Voltage- 1.171
PCH 2 Voltage- auto
PCH DMI Voltage- auto
PCH COMP Strength- auto
XCLK RCOMP Voltage- auto
CPU PLL Voltage- 1.725
CPU Config:
HT- disabled
Active Processor Cores- all
C1E- enabled
C3- disabled
C6- disabled
Package C- disabled
CPU Thermal Throttling- enabled
Limit CPUID Maximum- disabled
No-Execute Memory Protection- enabled
Intel VT- enabled
Hardware Prefetcher- enabled
Adjacent Cache Prefetch- enabled
LN2 Mode- enabled
All Core- 54
BCLK- 100
CPU Voltage- fixed
CPU LLC- level 2
IGPU Voltage- auto
IGPU LLC- auto
DRAM Voltage- 1.65v
PCH 2 Voltage- auto
CPU Config:
HT- disabled
C1E- enabled
C3- disabled
C6- disabled
Package C- disabled
Intel VT- enabled
