JLMitchell
- Jun 10, 2017
Hello, this is my first post on the forums. I have just built a pc and have completed my loop. I ordered a bridge tool for the 24pin to easily run the pump while leak testing. I can not get the PSU to power the pump. Coming from the pump is a molex connector with 2 pins. I have connected this to a cord I have that has 2 molex connectors and a 6 pin on the other end. I plugged the 6 pin into the PSU. Also coming from the pump is a 4 pin connector with one wire leading to it. I have plugged that into a pinout on the mobo that says "sys_fan_pump". I plugged the motherboard plug into the PSU and the other end has the bridge tool plugged onto it with the wire to trick the PSU. I have plugged the PSU in, flipped the switch, waited, pump does not come on. I'm not sure what to do, just a tad upset! I would really appreciate the help, thank you all. PC specs posted below
SeaSonic - Snow Silent 750W 80+ Platinum
XSPC D5 Photon Reservoir/Pump Combo
XSPC ATX PSU Bridge Tool (24 Pin)
I7 7700k (watercooled)
Gigabyte z270x Gaming 7 (watercooled)
Corsair 4x8 DDR4 3000 MHz (watercooled)
Samsung 850EVO 500gb
Zotac gtx 1080ti (watercooled)
Thermaltake Core P5 case
