- Aug 17, 2001
Hello! I got home for semester break when my parents told me that the computer was just restarting infinitely. I took a look and was just receive a BSOD with a registry error. I searched MSKB and found THIS ARTICLE to start. These are the steps I have taken in order and any results I may have had:
1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
lick to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:
md tmp
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
**Problem**I couldn't copy the default file so I renamed it to defaultold and then copied it to c:\windows\tmp\
I then:
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
I did NOT delete default for right now so I skipped that step, then I:
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default and overwrote any default that was in that folder.
I then booted into windows and it booted, and I could see all of my files, but it asked for activation and I just ignored it (the OS was already activated legally anyway.) I then set the necessary file permission in the MSKB article and went to view the system volume information folder. I was denied access so I followed THIS KB Article, but my only difference was that I had to right-click on the folder, go to properties, then security, and added Administrator as a user with full rights. The only user at that time was SYSTEM, but I didn't touch those permissions for whatever reason. With the administrator changes, I was able to view and move the registry files. so I:
Copy the following files to the C:\Windows\Tmp folder:
• _REGISTRY_USER_.DEFAULT
• _REGISTRY_MACHINE_SECURITY
• _REGISTRY_MACHINE_SOFTWARE
• _REGISTRY_MACHINE_SYSTEM
• _REGISTRY_MACHINE_SAM
and then
• Rename _REGISTRY_USER_.DEFAULT to DEFAULT
• Rename _REGISTRY_MACHINE_SECURITY to SECURITY
• Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
• Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
• Rename _REGISTRY_MACHINE_SAM to SAM
I rebooted into the recovery console and:
del c:\windows\system32\config\sam
del c:\windows\system32\config\security
del c:\windows\system32\config\software
del c:\windows\system32\config\default
del c:\windows\system32\config\system
copy c:\windows\tmp\software c:\windows\system32\config\software
copy c:\windows\tmp\system c:\windows\system32\config\system
copy c:\windows\tmp\sam c:\windows\system32\config\sam
copy c:\windows\tmp\security c:\windows\system32\config\security
copy c:\windows\tmp\default c:\windows\system32\config\default
and rebooted again...
Now the Problem... I see the logon screen with my only user like from a month ago when the computer worked. I click on the user, but am told that I have to activate it in order to login. I click ok, and I receive a "memory can't be accessed" error and rturn ot the login screen. I then choose cancel and receive a "message terminated" error and return to the screen. I tried logging into safemode, but there I see an "administrator" character and my family login... the family was the administrator before...
Does anyone have any helpful ideas what to do? SHould I just have my parents buy another HDD and set it as slave to retrieve the data and reinstall windows? Thanks for any help, as always.
md tmp
I then:
and then
