- Jul 8, 2010
Hi. New here!! Building a pc from parts -
Asus A7N8X Deluxe
Athlon 2200+ CPU 1.9GHz
FSB = 400MHz / CPU Freq = 200MHz / CPU Multiplier = 9.5
2GB GSkill DDR ram 400MHz
Onboard: Has 2 Firewire connectors / 2 SATA connectors
Is there anyway to run a Raid PATA PCI 133 card and Raid Sata via Asus A7N8x Deluxe MB? - seperate raids.
Earlier, bought 2 WD 500GB HDD + Koutech PCI 133 Raid card to setup Raid 1 - Found this works only when A7N8x Deluxe MB Sata is jumpered off. Didn't know board was A7N8X Deluxe board. That it had Sata. Checked it visually: saw SataLink chip. Must be more than A7N8X board!!
Testing:
1. Koutech PCI 133 Raid card to setup Raid 1 works only when Sata is jumpered off.
2. Taking out Koutech Pata Raid card + jumpering on Sata, when booting, PC sees Sata controller, reports no Sata drives, and boots into Primary IDE Pata drive XPPro ok.
3. If I have the Koutech Raid Card installed, with Sata jumpered on - boot sees the Raid Card, then sees Asus onboard Sata Raid - and hangs and doesn't boot into XPPro. This happens even after uninstalling the Sata Raid Conroller driver then booting PC.
Asus A7N8X Deluxe
Testing:
