Hi!
I have an extremely annoying issue with an Asus AM1i-A mobo and an Athlon 5350 that I've recently purchased. It would serve as a home server, but I never intended to use it on stock speed. This platform / this APU "asks for it", yet overclocking makes it pretty darn' useless. I see many people are overclocking these and I've successfully did so myself (didn't want to push it so hard, only 120 Mhz Bclk), BUT there are 2 things that every overclocker fails to mention:
Having an USB 3.0 external hard drive that is the main media storage of this system, the above behavior is unacceptable. I've tried different BIOS versions, I've tried changing around A LOT of BIOS settings, tried installing USB 3.0 drivers (there are none for Win8 and above), but nothing helped this far. As soon as APU Frequency (Bclk) leaves its beloved 100MHz, USB 3.0 functionality goes out the window.
Has anyone ever seen something like this? Is there a workaround??
- Any Bclk speed above 105 MHz insta-kills the AHCI controller. According to what I've read this behavior is inherited from the FM1 platform and can indeed be surpassed by setting the SATA controller to IDE mode. This is stupid, but I could still live with it, though it would have been nice to know it in advance.
- However, there is another game-breaking issue for me that made me absolutely lose my mind about this rig that I've recently started referring to as little **** because of this: if you touch the Bclk any way at all, if you change it from 100 MHz to something else, including so minor changes as 99 or 101MHz, then the integrated USB 3.0 xHCI controller blows itself to oblivion. It doesn't die entirely, but instead enters some kind of a safe-mode, falling back to acting as a standard USB 2.0 controller.
