- Thread Starter
- #21
You are the man Boberstergizone! I couldn't find a list of any commands for AFUDOS. I had tried the /nodate switch which works for one of the flash tools but not for AFUDOS apparently. Thanks again, I'll give it a try tonight.
2. From the research that I did last night I believe I hosed myself using the /pbnc switch as this wipes the boot block where the CrashFree2 data is stored. :/
I could use a little LUCK!!
Thanks
The chip to the right of the SB heatsink and left of the IDE port is a removable bios chip.
Well not using /pbnc was a sure no flash. Well make that no flash to an earlier bios version.
RGone...
Out of curiosity, if you buy a new BIOS chip for the board, does it have to have a BIOS on it or can you buy a blank chip and then put the BIOS of choice on it?
Yes you can buy blanks but you need a bios flasher to get going, if I am not wrong or hotflash the bios in another board. However the location I looked at will flash the bios you ask/tell them to flash to it. I would of course want a very early one.
RGone...
