I've got an Athlon X2 7750 BE on an Asus M2A74-AM motherboard.
It originally had my ram running at 533mhz (266x2), I changed it to the 1066mhz (533x2) it should have started at. There are no options to crank it higher than that*, or to control the memory:fsb multiplier (currently 16:6 on 200mhz). I assume if I raise the fsb it will raise the ram or will it change the multiplier to compensate and get the memory as close to 1066 as possible no matter what I put the fsb at?
*It only had basic options like 266, 400, 533. No 1mhz increments or anything like that.
Can anyone recommend a more robust Bios if anyone knows of one, or point out something that will get my ram running at higher clocks?
