I'm having strange temperature reports with the following Overclocking specs:
CPU: E4300 @ 333x9 - 1.35Vcore, 1.25V NB
HS: Scythe Ninja w/ yate-loon 120mm
Mobo: P5K Dlx
RAM: 4x1GB 2T Crucial DDR2-1000 Balistix @ 2:3 ratio
Upon first assembling & starting the PC, I'm getting good temps.
Idle:
Ambient:19C
CPU: 19C
Mobo:30C
Orthos 3hrs Load:
Ambient 19C
CPU:39C
Mobo: 40C
On the same day, I've tried OC my CPU to 333x9 = 3GHZ. New temps are:
Idle:
Ambient:19C
CPU: 28C
Mobo:35C
Orthos 8hrs Load:
Ambient 19C
CPU:42C
Mobo: 50C
Everything was okay until the next day, with the same OC specs,
Idle:
Ambient:23C
CPU: 38C
Mobo:35C
Orthos 10min Load:
Ambient: 22C
CPU:65C
Mobo: 52C
The temperature sky-rocketed from idle @ 38C to 58C in couple seconds after I started Orthos, then slowly creeps to 65C within the next minute.
I've tried resit the CPU, lapped the Scythe ninja, CPU temps only improved about 3C at idle and load.
The weird thing is that, when I feel the temp at the base of the Ninja, it's very cool, not l ike 60+ Celcius like reported. While the NB HS and heatpipe are hot (like how they supposed to according to the 50C mobo temp)
The CPU temp was read from Asus AI, Asus Probe, and Core temps (reporting both core temperatures about the same, +/- 1C).
Anyone else experience the same???? I don't know why it's reporting that high but the temp on the pipe and the base of the Scythe Ninja is very cool.
Mobo: P5K Dlx
Idle:
Ambient:19C
CPU: 19C
Mobo:30C
Orthos 3hrs Load:
Ambient 19C
CPU:39C
Mobo: 40C
Idle:
Ambient:19C
CPU: 28C
Mobo:35C
Orthos 8hrs Load:
Ambient 19C
CPU:42C
Mobo: 50C
Idle:
Ambient:23C
CPU: 38C
Mobo:35C
Orthos 10min Load:
Ambient: 22C
CPU:65C
Mobo: 52C
