- Mar 4, 2011
Hi everyone,
I apologize for having to bother you all with this but I've read a million and a half articles on overclocking and haven't been able to get my CPU as high as I'd like yet.
I know my set up is getting older, so I'd like to get a little more out of it. There are so many options in the ASUS bios that I'm not sure how to configure everything.
I have an E7200 on an ASUS 5PQ Pro motherboard. Ram Mushkin Enhanced Blackline 4GB and graphics card is ATI 4870. I have put links to it all below if anyone wants to see the specs.
http://www.newegg.com/Product/Produc...82E16835200026
http://www.newegg.com/Product/Produc...82E16813131299
http://www.newegg.com/Product/Produc...82E16820146785
http://www.newegg.com/Product/Produc...82E16814129113
My CPU is currently up to 3.48 with a FSB of 410 and an mlt of 8.5. Whenever I try to up the mlt above 8.5 I get a rounding error in Prime95 or I get a blue screen data dump before windows loads. My voltage is already at 1.36 (I was planning to work on decreasing it once I got the speed where i wanted it) so I don't think I need to up the voltage anymore. Any one with any thoughts on why I can't up the mlt above 8.5? I also can't up my FSB above 410 and now I just saw that even on 410 x 8.5 my second core is failing in prime.
Per CPUID here's my processor stats atm.
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E7200
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping M0
Technology 45 nm
Core Speed 2460.1 MHz
Multiplier x FSB 6.0 x 410.0 MHz
Rated Bus speed 1640.1 MHz
Stock frequency 2533 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 3072 KBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.5x
Max VID 1.213 V
TDP Limit 65 Watts
Processor 1 ID = 0
Codename Wolfdale
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping M0
Technology 45 nm
FID/VID Control yes
Max VID 1.213 V
TDP Limit 65 Watts
