- Feb 17, 2005
Asus lists a bunch of E5 v2 Xeons as compatible here:
https://www.asus.com/us/Motherboards/P9X79_PRO/HelpDesk...
Normal P9X79, same list:
https://www.asus.com/us/Motherboards/P9X79/HelpDesk_CPU...
The Intel spec doesn't even list Xeons as supported for the X79 chipset:
http://ark.intel.com/products/64015/Intel-BD82X79-PCH
Officially supported E5 2660 v2:
http://ark.intel.com/products/75272/Intel-Xeon-Processo...
Unknown E5 2660 v1:
http://ark.intel.com/products/64584/Intel-Xeon-Processo...
The v2 has 'OS Guard', 'Secure Key', and slightly higher memory bandwidth. The newer one also lists not having TSX-NI, but neither do. The supported one has 2 more cores...
I found the v1 available for $120, instead of like $1k. Hoping for a cheap upgrade to PCIe 3.0
2660 v1 not listed:
http://www.cpu-upgrade.com/mb-ASUS/P9X79_PRO.html
2660 v1 listed as supported, so maybe the v1 requires ECC?:
http://www.cpu-upgrade.com/mb-ASUS/P9X79_WS.html
http://www.cpu-upgrade.com/mb-ASUS/P9X79-E_WS.html
Unknown E5 2660 v1:
2660 v1 not listed:
