This is killing me. It's quite a puzzle.
I installed my new mobo, CPU, RAM and liquid cooler (the Corsair H-100). Here's the ugly thing: when I installed the cooler, I initially did not remove the cover on the H-100's contact for the CPU. I booted it up, and in a couple minutes, while I was in the CMOS, it shut itself off. I restarted, and saw CPU temps around 89C. And after about 3 similar starts and stops, I realized that I had not removed the cover, so I did so. There was no visible damage to either the cover or the CPU (or the cooler). But after setting it up right, I was still getting CPU temps starting about 88-89C, then it would get hotter and shut down again in a couple minutes.
The two 120mm fans on the radiator of the H-100 were clearly working hard. The radiator didn't even feel warm, and the lights and control on the H-100 seemed to be working right, but I couldn't hear any pump noise at all.
So I thought I'd eliminate one factor and zipped out and bought a Corsair H-80 (similar cooler, but smaller radiator). I installed that and got the same results: temps about 89 degrees C right away, then shutdown in a couple minutes.
So I thought I'd eliminate another factor: maybe the CPU had been damaged somehow...I bought a 2nd one and put that in. Same problem. I tried setting the CMOS to Ignore the CPU temp, but it still shut down in a couple minutes.
(BTW, I was getting "CPU over temp" messages when I booted.)
So if it's not the cooler and not the CPU, is the mobo suspect? Could it's thermometer be reading wrong? I didn't feel a lot of heat around the CPU area, but not sure if that's significant.
I'd be very grateful for suggestions!
