Hello,
I recently build a new pc and was planning to use my 2 years old Corsair H115i (used about 10 hours in 2 years):
https://geizhals.at/corsair-hydro-series-h115i-cw-9060027-ww-a1376680.html
System:
Asus B-550 plus
Ryzen 3600
Fractal Design Meshify
The cooling power was very bad:
CPU block mounted, both tubes down
radiator at the top
Prim95: 75 - 85 0 - 5min
85 - 100 ~7min
water temperatur ~32 always
nearly no effect on fan pwm
pump at max (pump speed does change temp drastic)
CPU block, both tubes to the right
radiator at the top or front (tubes down)
Prim95: 65 - 75 0 - 5min
75 - 90 ~7min
water temperatur ~32 - 36
Corsair H60 about 5-7 years old, uptime since i bought it:
https://geizhals.eu/corsair-hydro-series-h60-2nd-gen-cw-9060007-ww-a875898.html?hloc=de&hloc=at
radiator at the top
Prim95: 55 - 65 0 - 5min
65 - 75 ~10min and stays there
water temperatur NA
pwm effects temp radical
first i was thinking that the H115i doesnt have enough mounting pressure, i checkd it couple times. it was mounted correctly.
the H115i was used on a threadripper 1950X and it was preforming quit ok, i had the feeling it was just not a very good cooler.
Is there something im missing, or is the H115i just a crappy cooler?
how can a 5~ year old cooler outpreform this huge much newer cooler.
System:
Asus B-550 plus
Ryzen 3600
radiator at the top
85 - 100 ~7min
75 - 90 ~7min
radiator at the top
water temperatur NA
