I have the below system that has been running without an issue for 2 years. It is not oveclocked, it is water cooled.
ASUS Rampage 5 edition 10 4x16 GB
Corsair Dominator Platinum Series DDR4 64GB 4x16GB
Intel Core I7 6850k Samsung 960 Pro M.2 2280 Mz-V6p1t0
2x Titan X Pascal GPU
EVGA Supernova 1200 P2 PSU
This morning when I turned it on it did not post. the motherboard says code 00. The motherboard appears to be getting power, all the fans work, the pump works, the LEDs on the motherboard work. The EVGA bridge lights up between the Video Cards.
After a time the four memory lights are glowing (on the motherboard). The Ln2 switch is off.
Can you recommend debug steps please. Would you swap out the CPU or the board first?
Have never had an issue like this. Would appreciate any help.
