- Jan 2, 2003
- Nebraska USA
I'm a World of Warcraft player, might not be good at it but I love playing it... about a month ago I upgraded by router to the Asus RT-AC3200 and ever since I got loading lag in World of Warcraft. What I mean by loading lag is when I hearth or take a portal to a main city or use death gate as a Death Knight. The screen refreshes like it should and the progress bar fills up then it just sits there, for 30sec - 1min before I load in to the zone or area that I was headed too.
I have tried a ton of things, this modem has all sorts of settings, none have worked. DMZ failed, thought it would be a sure winner. There is a setting with in the router port forward for WOW using port 3724, didn't work. I disabled and shut down my av Kaspersky, didn't work. On a Blizzard post I found somewhere searching it said Wow uses ports 3724, 1119 & 6012 so I forwarded them all and still didn't work. Turned off the router protection, didn't work. Turned off the router Adaptive QoS, didn't work.
I've fiddled with every setting possible hoping to stumble upon the answer, nothing worked. Anyone got an idea what might be the issue? Am I overlooking something simple?
Modem - Linksys CM3024
Router Asus RT-AC3200
