- Feb 3, 2008
I am running 64-bit Vista and I can't get ASUS SmartDoctor to not start up with the OS. I tried msconfig and Windows Defender but it doesn't even show up in the list of startup items. Any hints?
In msconfig, check the services tab. There is a way to stop it from running
I honestly could not tell you, I have never run the program. What do you use it for? If nothing, just uninstall itI don't see it anywhere in services. Does it go by a different name?
You could always use RivaTuner instead. It can show them in games and down on the bar.
It is the only one I use for temperature monitoring for the GPU.
What I'll do tomorrow is get a copy of the program and install it unless it is one of those super intrusive, difficult to remove programs (*glares at norton*).
So, you have tried:
msconfig, going to the startup tab and unchecking anything that you don't want starting (basically, uncheck all and only start what you need).
msconfig, going to the services tab, not listed.
Try this:
Open regedit via the run command (regedit) and check these locations:
HKEY_CURRENT_USER < Software < Microsoft < Windows < CurrentVersion < Run
HKEY_CURRENT_USER < Software < Microsoft < Windows < CurrentVersion < RunOnce
HKEY_LOCAL_MACHINE < Software < Microsoft < Windows < CurrentVersion < Run
HKEY_LOCAL_MACHINE < Software < Microsoft < Windows < CurrentVersion < RunOnce
