- May 7, 2002
Hi all,
I bought the ASUS VG248 1ms monitor about a week ago. Since I've been using it I've noticed that I will get an intermittent blank screen. It happens typically when I am playing games but it actually did it at the desktop when I was pulling up chrome to write this thread. Basically the screen goes completely black as if it lost input for about 3-5 seconds then comes back fine. Not really sure where to start my troubleshooting on this one. Should I suspect my video card? I have two monitors connected to the same card and the other monitor is a back lit LED also from ASUS and has been fine for years. Both are connected with DVI and I have only display 1 enabled in windows which is the VG248. Have not tried swapping the cable but that is probably where I will start. I also have not installed any of the ASUS drivers so I might try that as well but I figured since everything is pnp that shouldnt be an issue. I have a PS4 hooked up to the HDMI port on the same monitor that is giving me issues and have not had issues with about 20 hours of use so far. Any thoughts? Much appreciated... thanks a ton as usual. Much <3 ocers!
