- Jul 23, 2013
- Houston, TX
all the parts i have are below. I booted up the pc for the first time last week and it started up smooth and perfect.
I haven't left this PC on all the time like my last one, so i've been turning it off every night. well, day 2 and i try to turn the pc on when i get home from work, and nothing. it doesn't beep like it did the first go around. All i get is a RED LED CPU light. turn the pc off and back on, same thing. Lastly i hold down the power button to shut it off then wait about a second and turn it back on. It boots up and i get a bios error message stating "cpu overclock failed".
well, the only problem is i hadn't even tried to over clock it yet. But, i went into the bios like it said to. I didn't change anything, exit the bios then it boots up normal.
now, every time i shut the pc down it does this and i have to repeat the above to get it to boot up.
i chatted with asus and they said to swap out the mb, so i called newegg and had them ship me a new one.
Well, i just put it all back together and alas, i boot it up again for the first time and i get the infamous RED CPU LED. Do the same proceedure of holding down the power button till it shuts off, then fire it back up and i get the "cpu overclocking failed" bios message, so again i press f1 to go into setup only to see that nothing is wrong and exit the bios without saving and it boots right up....
what is going on?! do i have another bad asus mb? Could it be the core i5 giving me problems?
i should also add, that when i "restart" the pc and not shut it down... i don't have any boot issues. This is only when i shut it down.
please help! i'm frustrated and need to find out what the cause is so i can replace it and get this fixed asap.
